Search the forum,
Discuss Supply to airbnb thats been prewired by a friend in the UK Electrical Forum area at ElectriciansForums.net
A friend of mine wired a 10mm 3 core armoured cable to his shed before I got involved and wired it himself already. He wants make it an air bnb with a ring circuit 32a, lighting circuit 6a, induction hob circuit 32a and a underfloor heating circuit 20a. Will the 10mm be enough for the supply and what size breakers would people recommend? For the mcu feeding the shed and the mini board in the shed? Thanks
I think some calculations and design are in order here. Especially if he is renting it out to the public.
He definitely needs to get an electrician in for this.
one of the NVQ tasks must be to calculate a power circuit to a shed or garage so should be a bread and butter cable calc for someone of level3/ it certainly was when we did 2360 back in the day
it must be a nice 'shed' if you are going to be renting it to paying customer s
I've elected to undelete this thread because the reason given by the OP when he deleted it was 'Unhelpful' which I think in this case translates to 'You guys didn't give me the answer so I'm going to simply delete'.
As has been pointed out @jkeeble , if your profile is a true reflection of your skills and capabilities, doing the calculations required for this should not be beyond you. So either you're unsure and would like a second opinion or you can't be bothered. If you're not sure, then do the calculations for the design and hit us up with that along with 'here's what I've worked out' and we'll be more inclined to assist rather than just advice you seek the services of a competent electrician.
Reply to Supply to airbnb thats been prewired by a friend in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
5K
Hello, I am renovating a house. I am rewiring myself. I am getting an electrician to install a new consumer unit & test all my work. I'm looking...
I'm planning to build a shed in the far RH corner of the rear garden. It will have a reinforced concrete base, wood structure, flat roof and be...
Basic question to see if what I wish to do is correct: Client wants to build (or is building) and outside room (roughly 8m by 4m) to be used as a...
After my last post and having and having to re-learn some stuff can someone check and advise on a few things. Sorry if this is wrong don't hate...
