Search the forum,
Discuss Adding 12v strip lights to kitchen cabinets. in the DIY Electrical Advice area at ElectriciansForums.net
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the wall units for the strip lights to connect to but when I measure the voltage with a multimeter it recording as 12v AC max, from what I can see online led drivers I found online expect 220-230v to convert down to 12/24v and I know you shouldn't connect strip lights to Ac.
So my general question Is what should I use to connect the cob led to the mains to change the AC to DC. The lengths are are below 2m. Wattage will be 40w and these will be controlled by 3 gang led dimmer switch
Thanks any help is appreciated.
Can you provide photographs?
There may be existing transformers or drivers sitting on top of the units.
Not all LED drivers are dimmable, even with a proprietary LED dimmer.
Model numbers or data sticker on the existing lights should state the voltage they run at.
Reactions: DPG
Thank you for your reply.
I manage to find the issue I think, the natural and live wasn't inserted properly in one the wago Further down causing the voltage drop most likely.
Reply to Adding 12v strip lights to kitchen cabinets. in the DIY Electrical Advice area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
