Discuss 3-Ph sub-mains on four 16mm DI singles. OK or not? in the Commercial Electrical Advice area at ElectriciansForums.net
Mark42
Patron
I'm upgrading an existing installation in my own house, and would like a second opinion please.
An existing sub-main, in a separate building about 10m from the supply is fed via four existing 16mm DI meter tail cables in cable tray and conduit. I inherited this installation from when the very rural house was split-phase (ie L1, L2, N, E).
I now finally have a 3 Ph supply and want to exchange the remote DB for a proper 3 Ph board.
May I simply add one more 16mm DI 'meter tail' cable to the existing arrangement? (L1, L2, L3, N, E, all correctly labelled at each end).
I can't see why not. (And I do know about eddy currents and all the singles going through the same hole in any metal enclosure :))
Am I missing anything?
Cheers
Mark
see which is most cost effective, the extra single or the NYY.
Thanks. But this is a totally separate job to my NYY question.
The latter is effectively new-build. This is a simple upgrade.
I just wondered what others' opinion of five single 'meter tails' running along cable tray then across an alleyway in conduit was. It looks ugly, but I can think of no reason why it's not OK electrically.
Reply to 3-Ph sub-mains on four 16mm DI singles. OK or not? in the Commercial Electrical Advice area at ElectriciansForums.net
Hi, searched the forum but cant locate anything similar so apologies if ive missed something. Ive got a new hob to install in the kitchen...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Hi, Posted here as I'm not an electrician, not because it relates to anything I'm considering "Doing Myself". My late parent's house is supplied...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
