Discuss 3 Way Dimmer switch in the Australia area at ElectriciansForums.net
Sav
Hi everyone,
Hope your all well and busy !
Going to see a minor job. Lady wants hallway downlights (dimmable Aurora transformers are already fitted ), to operate on a 3 way switch system.
She wants a dimmer at one end, normal intemidiate switch in middle and dimmer at the other end.
As far as I know, if you have a set up like this, the lights will flicker due to the dimmers conflicting with each other ?? I am not sure on a 2 way if using dimmers would be ok, I think they would.
I had a similar setup a while back and I remember fitting Varilight units, whereby you have a master and two slave dimmers, that way, all 3 can be dimmable.
Is that correct people, or have you had any similar expierences and found a way around it?
Thanks and best regards,
Sav
Two dimmers can be used however, if one dimmer is turned down to 50%, leaving the second at 100% power and then the next operation is from the switch with 100% control it will only actually have 50% of operation, (unable to turn the light levels up above what the first switch is set to...
Not an ideal system...
Hope that reads okay...
Reply to 3 Way Dimmer switch in the Australia area at ElectriciansForums.net
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Morning All Got little bit situation going on, causing multiple visits (luckily only 2 mins drive from where we are.) Client not 100% happy with...
