Discuss 4 pole 3 phase breaker in the UK Electrical Forum area at ElectriciansForums.net
I have above mentioned breaker which does not have any markings to show which is the neutral pathway, I wish to fit it directly above a 3 phase 4 way surge protector which has its neutral on the right hand side and so would ideally want to connect the neutral above it on the right hand side of the breaker. Its being situated in a two tier consumer unit, in France its normal to put the neutral to the left hand side and its usually marked as such. The breaker as 4 symbols for magnetic cut off and disconnection of all 4 pathways, all similar for each pathway. Any advice welcomed.
A photo might help!
In general 4P MCB as just that, 4 identical thermal-magnetic units mechanically linked so if any trip they all go. As such it matters not how you use it, but matching other devices allocation of L1-L3 & N makes sense.
A photo might help!
Thanks, thats what I assumed , many different manufactures make similar models to mine, again unmarked. As to the photo I will need to join another forum to teach me how to do that!
Reply to 4 pole 3 phase breaker in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, Quick question can you fit an RCD without any neutral connections? If I have a 3 pole circuit breaker which has all 3 poles...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Hi, searched the forum but cant locate anything similar so apologies if ive missed something. Ive got a new hob to install in the kitchen...
