Discuss Accuracy of test instruments in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Sly
Good afternoon gentlemen
Could you help mi please with Test instrument accuracy record?
How should I do it right?
I do it a first time.
Thank you
You will need a calibration certificate as its your first time therafter its up to whoever you are registered with some require annual calibration others providing you are checking frequently wont worry about the annual calibration
Chris
I am Nic eic domestic installer and I waiting for Periodic Assessment (first time).
I have no idea how can I do Test instrument accuracy record.
I have got calibration certificate.
Sly
Hey.
I use one of these for checking my instruments along with a dedicated socket in my garage for live tests. If you buy one of these you get a test schedule with it which I then copied onto the PC and adapted it to suit.
Don't forget to test your RCD ranges on your meter. If your socket that you use for loop testing hasn't an RCD then go down to Homebase or similar shed and buy a plug-in RCD to test.
BTW, I've always got measurements for my meters once every month.
Reply to Accuracy of test instruments in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, I currently have a Megger 1730 v1 which is fine for all functions except the 2 wire (L-E) no trip loop test, (no 3 wire loop test on my 1730)...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Please help resolve this techincal queistons: The customers industrial plant is supplied with electricity from the utility company via 2 transfer...
I start my BTEC Level 4 HNC Diploma in Electrical & Electronic Engineering in the new year, what book do you recommend to get to help me with my...
Hello everyone, I'm wondering if someone could help me with some EICR coding. I am aware that bringing mains tails into a fire rated consumer unit...
