Discuss Adding hi-lo beams with indicators in the Auto Electrician Forum area at ElectriciansForums.net
Rsjohnb
Hi, looking for a bit of assistance guys.
I’m going to mount a 4pod fog light assembly to my car. The lights I have chosen are 7” hi lo beams with indicators. Can I just take the wires (hi,lo,DRL&indicator) and connect these to the existing circuits? The instruction mentions relays and switches but I was hoping I could just tap into the existing wiring and use the existing interior switches.
John
You are at risk of burning out the existing wiring if you overload it , also the canbus may shut it out if it detects it as an overload.
A lot will depend on the power you wish to draw. A separate supply with relays to activate the lighting would be a way to do it .
I don't know what sort of lights you have, but if the "flash" position makes both dip and main beam come on together, then with a few more relays you can have that make all your auxiliary lights light up even if their switches are off.
Reply to Adding hi-lo beams with indicators in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi all, hoping someone might be able to help a little, we got our daughter a renault twizy, but the headlights do not work. The side lights...
Hi all. I'm trying to put a light-bar on my (facelifted) Land Rover Freelander 2. I'm wanting to wire it so the light-bar will be energised when I...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
