U
urchy107
just done my first private job which included a new lighting circuit, new radial, and extending a ring, in a workshop/ car port. the board had been installed new 6 months ago and had no rcd on any circuits so i put an rcd covering all circuits. do i now have to re test every circuit for the certificate or can i just do the ones i altered or added? also i had problems doing an rcd test which turned out to be a 100 ma rcd on a circuit which was powering a stable which is fed from a 40a type b breaker at the workshop board. the 100 ma was faulty so i just connected straight through as its covered by the 30ma i just installed. after this the rcd test was ok untill all circuits were on then the auto test would not run through, but each circuit would test out fine individually, i have a 40,32,32,16,6,6a breakers on one 63a rcd but theres not much load on any circuits? any advice is appreciated, thanks matt
