Discuss Advance Combi Boiler in the UK Electrical Forum area at ElectriciansForums.net
Forry1759
The new Advance Combi Boiler has a feed from consumer unit using 6mm cable on a 32amp breaker to a 45amp double pole switch. What size cable to the boiler should it be from this switch. It has a fused 3amp supply to the electronics section.
The flex should ideally be the same size as the supply cable, so 6mm.
Plus make sure you use ferrules where required, just a few broken strands on a load like this can be enough to cause a failure.
Reply to Advance Combi Boiler in the UK Electrical Forum area at ElectriciansForums.net
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
A BG fused connection unit, with neon. A boiler. Fuse out. Spur switched off. I was checking polarity after a colleague had 2nd fixed it and...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Is this ok? 32amp breaker with a 6mm wire leading to fused cooker switch. This then leads with 6mm cable to hardwire point. Can i hardwire 2 x...
OLDBOY
O
