Discuss Advanced fault diagnosis. in the UK Electrical Forum area at ElectriciansForums.net
Dave Appleby
Personally I think the starter is worn out. Should be IP rated to 45m???
Old school.... weird combination. BSAC, PADI, IANTD and NACD.
Yeah, similar here.
BSAC (Started and still sort of a member)
SAA
TDI/IANTD
Just thought you knew Craig - he is a PADI instructor, often using Preston Hill quarry - I use that for the shallow training stuff when I do trimix courses.
I've heard of mixed gas diving but mixed beer diving is a new one on me??
Yeah quadmix is pretty good
Start with oxygen, helium, nitrogen, and vick's vapour rub:
That's Scapa flow on the 100th anniversary - I was full of a cold but still wanted to dive - Vicks does work!!
Normally quadmix is oxygen, helium, nitrogen, and the aroma of the night before's beer!
Yeah, similar here.
SAA
TDI/IANTD
I know Craig from the Protect Preston hill group.
Looking at your quals. Ever tried cave?
Yes, used to work in florida a bit, so did a few caves, fantastic experience, but too expensive to travel for just a few dives, and in the uk caving is so different - there are a few mines which are similar to those caves in florida etc, but I tend to prefer wreck diving.
This weekend past we dived the forth, one of the k-boats and the Avondale Park (last ship sunk by a u-boat - just after the end of ww2).
So many wrecks, and comparatively easy to get to around Scotland that it's something one can do most weekends.
One of my friends emigrated to Cyprus, but ended up coming back to Scotland partially because of the diving here, in Cyprus there really is only the Zen' - which he knew too well!
Never been myself - hope you are enjoying it, your photos look great.
Julie.
Just back.
They are dropping wrecks everywhere at the moment. Also Green Bay north of Ayia Napa is an amazing dive for Turtles, they are magnificent and don't give a ----?
We had one 3 feet from us doing the turtle equivalent of the bear scratching on a tree.
4 last gratuitous photos.
The drop down the lift shaft into upper cargo and under one of the lorries. Remember she's on her side so the lift is actually a horizontal swim.
Reply to Advanced fault diagnosis. in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Folks. I need to install a defib unit outside on a wall. Does this require an RCBO or not, just wondering as the unit has a small heater within...
Hello, as a relatively newly qualified electrician (mature trainee who completed his NVQ in 2023) today was the first time I've seen a melted...
Today I was doing an EICR and went around a couple sockets with a Megger MST220 socket tester just to see if there was anything obvious, all three...
Hi all, I have a question regarding the breaking capacity of circuit protective devices. So, the breaking capacity rating of devices in domestic...
