Search the forum,
Discuss advice/help needed indicator light for machine in the UK Electrical Forum area at ElectriciansForums.net
714gold714
Hello there everybody
Was looking for some advice please.
Installed a power supply about a year ago for a machine- 3 phase 16amp off top of my head. I basically ran my SWA into unistrut in a 3 phase interlocking socket mounted on unistrust off the floor.
Basically the customer has now asked if i could install a indicator light on to the machine (portable on wheels) or the isolator, so that when the machine is running a light is visible to remind people to switch the machine off. Has anybody had a similar job and how did you do it.
thanks again
Hi gokl,
Does the machine have a control panel with contactors relays etc?
If so it will likely have a transformer for a control circuit, this transformer will likely be permantly
live when isolator is on,depending on voltage of the control circuit u should be able to wire a light from this.
However control panels are subject to different regulations than electrical installations e.g. type of wiring is different (e.g. tri rated).
Also the manufacturer prob wont be to happy about warranties etc!
Wiring a light straight from the isolator would require a 415 v primary transformer, not sure about fusing down for this as your wiring to transformer
will be a lot smaller than the supply and the fuse would be downstream!
Obviously I have no idea about the machine as you didn't say what it was, however when we used to wire machines we used to use auxillary contacts on the contactor and have a red and green light, the green light would shine when the machine was on, the red when the machine wasn't running but there was still power at it, only when the main isolator was switched off did both lights go off to let everyone who needed to know the power was cut.
we use this method as well if needed (most of our machines have an indicator light on them but occasionally the customer wants remote indicators added) or monitoring circuits added
Hello is basically for a very small machine that takes sharp edges off stainless steel there is no relays or contractors.
As somebody else said could I use 1 phase from the load side of isolator and use this to power light?
There's an indicator already present on the interlock isolator... if they are fluent in English they can actually read either the word ON or OFF.... simples
metal grid box, 1x 3 gang mounting frame, 1x 3 gang front plate, 3x grid neon, you can fuse it down to 3a if you have to.
God, the arguments i've had on, what colour means what over the years...lol!! I was taught that Green was ''ON'' and Red was ''OFF''!! Now it seems everything is reversed!! lol!! The argument being, that RED indicates danger, and GREEN indicates safe. Still confuses me to this day, when i see a panel full of green and red indicator lights, what i'm looking at!!!! lol!!
Reply to advice/help needed indicator light for machine in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
