Discuss Aico 3000 series smoke alarms,audio link. in the UK Electrical Forum area at ElectriciansForums.net
the 3000 series is compatible with all other aico alarmsJust checking if this mains/rechargable unit can be used without the audio link module as
my CEF catalogue does not make it clear.I just want to link 2 smokes with the wireless base to keep
the cost down.
Thanks for any advice,
Regards,S
the cost down.
Regards,S
Yes,Resu,I just want a wireless mains/lithium optical smoke to avoid damage to the decorations .Have Aico changed there range of smoke detectors?I think the OP means using the Ei168RC wireless bases instead of the Ei3000MRF modules.
You just need two alarms with the integrated wireless base and hose code them together.Just checking if this mains/rechargable unit can be used without the audio link module as
the cost down.
Regards,S
Reply to Aico 3000 series smoke alarms,audio link. in the UK Electrical Forum area at ElectriciansForums.net
