Discuss All Rcbos in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
Jack of all
Someones told me that to comply with the latest regs then a split load board with half the circuits as rcbos & the rest on mcbs with an RCD is no good & all rcbos is the way to go.
I can see the point but it seems overkill ???
Someone has been telling you porkies mate
Dual RCD CU complies with 17th full stop. Anything with RCBO's which will reduce disruption to rest of install under single circuit earth fault condition is going to be better but certainly not a requirement.
His idea was that no interaction between circuits is allowed & one circuit tripping the RCD and taking out several others is interaction.
Thanks for the replies ... I'm not totally up to speed with things & I'm thankful of that input..
He is right in what he is saying. However it is not a requirement. Ask him to quote regulation that stipulates RCBO's.
The Regulation that refers to this is: "314.2 Separate circuits shall be provided for parts of the installation which need to be separately controlled, in such a way that those circuits are not affected by the failure of other circuits, and due account shall be taken of the consequences of the operation of any single protective device."
An all RCBO CU/DB be they SP+N or SP is by far superior to the common split 17th ed CU's or it's predecessors. They are to all intent and purpose, an industry cost effective compromise, that to my mind is not really fit for purpose. eg, ...a problem on one circuit can and will affect several other circuits.
Where a TT installation is involved, the RCBO's should be SP+N or DP.....
I know the trade does love it's abbreviations & changing the names for stuff & since it seems that earth has to be T for Terra then the old PME (permanent earth .. now defunked ) ought to be PMT...
LOL
LOL
Permanent Earth???? what's that then
Reply to All Rcbos in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
