Discuss Anything wrong with this socket install? in the UK Electrical Forum area at ElectriciansForums.net
17 minutes!. thought I was slow. I'd have done it in 8 minutes, and I'd have allowed enough cable to dress the flex conduit neatly.
I quite like his comment about there being no minimum depth..... :fearscream:
he's partly correct there though. the regs. say it should be buried at a depth where it's not likely to be damaged by normal activities like gardening. in soil, the sensible depth would be around 600mm but under paving, could be a lot less.
And there's more
But he is just twisting the regs there in my opinion... You should allow for a depth greater than gardening tools like spades or forks.
I agree
this one takes the biscuit for endless useless waffle.
I do like the chalk pen though..
Wonder why someone would do this, this is how i imagine the conversation went.
Barry - "Janet can you just come outside and video me putting up an outside socket"..
20 mins later..
Janet- " You are good Barry, that £3000 was really worth the money, maybe you could even go into teaching"
Barry- " I know, electrics is easy. Here you go, hold that.. seeing as ive got my tools out you may aswell that a video of me putting up a new light".
Janet " Ok love".
Reply to Anything wrong with this socket install? in the UK Electrical Forum area at ElectriciansForums.net
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
Today I was doing an EICR and went around a couple sockets with a Megger MST220 socket tester just to see if there was anything obvious, all three...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
I am in UK and have just built a summerhouse and inside is a large LG flatscreen TV. I purchased an aluminium pole, ran the cable out and up...
