Discuss Assignment Help Please in the UK Electrical Forum area at ElectriciansForums.net
Hello,
Please can someone give me some help with this part of my assignment.
Which bit are you struggling with? You don't even have to get the lux levels anywhere near.
Look at some nice looking non corrosive LED fittings For the damp areas and don’t forget about emergency lighting on both sides of any external fire exits, stairwells. You will need sufficient lighting to get to the exits as well. I think they should be maintained due to it being a public area.
Mark them on the plan view and print out the data sheets.
I don’t think it’s asking for much more.
A LED Lighting System is THE Solution
LED luminaires have greatly evolved over the last few years. They are more resistant; they project much less heat; they are less energy intensive than in the past and they have a longer lifespan than their traditional counterparts. Their durability is a key factor in the low maintenance of these lighting systems, especially in a costly environment such as indoor pools.
There you go, you've found a nice web page to cut and paste from. Now all you have to do is work out which bits are specific to Canada, and which are more general and can be applied to the UK. :)
Reply to Assignment Help Please in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone Just looking for some advice and guidance on approaching my HNC in electrical engineering and bridging units. How did other people...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
Im currently in my apprenticeship and completing an assignment that involves cable calculations. Im currently stuck on how to find the design...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
