Discuss Bodge Job! in the UK Electrical Forum area at ElectriciansForums.net
rolyberkin
Just fitted four new fire rated down lights to be faced with this, made my day..............not! So two of the six have been fitted below joists which have obviously been hacked out by the previous sparks, give me strength.
I have three like that in my bathroom. Probably were running for years with 50w GU10s. Replaced with LEDs but a longer term solution is on my longer term to-do list. No quick fix really, the woodwork in the loft needs mending I suppose, and the lights relocating. Which will then mean holes in the ceiling to repair. But then the three I move will be out of alignment with the other lamps. Just awesome really.
I am considering cutting a fire rated light down to lose the height, won't be fire rated but what was there wasn't either. No issues with heat or damage, tiled bathroom floor above. There is a even a cable routed in the joist above so no excuse really, just a complete ----wit!
Hi - these are quite shallow at 2" and I'm sure there are others so hopefully you won't have to cut down a fitting :)
http://www.NoLinkingToThis/p/smartw...3w/6267h#product_additional_details_container
Reply to Bodge Job! in the UK Electrical Forum area at ElectriciansForums.net
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Posted from another forum "Pretty easy to spot exactly what type of client you're talking too once you've met and dealt with several, and I used...
