R
rattlehead85
Need a bit of advice to clear up some uncertainty. We have a TN-S earthing system supply at the house. Main gas and water are bonded using 10mm cable. Supply running to shed at bottom of garden is 3 core 6mm using house earthing system protected at the house by 32a mcb with RCD metal board in shed. We have a metal frame pergola bolted to the ground which has an ip65 socket and light on it. The frame tests as extraneous back to M.E.T in house. Can this be bonded using 6mm back to the board in the shed and use the existing earthing conductor contained within the swa feeding the shed to get the bond back to the m.e.t of the installation or will i need to run a dedicated 10mm directly from the m.e.t to the pergola frame meaning i need to trench dig back to the house. Advice appreciated.
