Discuss building control fee for electrical work even though its my job in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i did go in but the q put me off so rang when i went back on site, to be honest they didn't even sound confident in what they were telling me, spoke to a bloke on site today his neighbour is an electrician for his family building firm and he's not registered as they do extensions and loft conversions and because you pay for building regs that includes electrics and i've just found my paperwork and it states electrical work must be installed and tested to to building reg part p and a bs7671 certificate issued.
that's exactly the point. you have them over a barrel with that. stick to your guns. you are right , they are wrong.
[h=3]Part P FAQs IET Quote[/h]
[h=2]Q1: When did Part P come into effect?[/h]Part P came into effect in England and Wales on 1 January 2005.
[h=2]Q2: What are the requirements of Part P?[/h]As of 1 January 2005 it is a legal requirement for all work on fixed electrical installations in dwellings and associated buildings to comply with relevant standards. The relevant UK standard is BS 7671:2008, 'Requirements for electrical installations' (The IEE Wiring Regulations 17th Edition). BS 7671 covers requirements for design, installation, inspection, testing, verification and certification.
[h=2]Q3: To what types of electrical work does Part P apply?[/h]
  • In or attached to a dwelling
  • In the common parts of buildings serving one or more dwellings, but excluding power supplies to lifts
  • In a building that receives its electricity from a source located within or shared with a dwelling, and
  • In a garden or in or on land associate with a building where the electricity supply is from a source located within or shared with a dwelling
The term dwelling includes houses, maisonettes and flats. It also applies to electrical installations in business premises that share an electricity supply with dwellings, such as shops and public houses with a flat above.
The common parts of buildings includes access areas in blocks of flats such as hallways and shared amenities in blocks of flats such as laundries and gymnasiums.
Part P applies to electrical installations located in outbuildings such as detached garages, sheds and greenhouses.
Part P applies to parts of electrical installations located on land around dwellings such as garden lighting.
Part P applies to electrical installations that operate at voltages not exceeding 1000 V a.c.
Notifiable work includes new installations, house re-wires, and the installation of new circuits. Notifiable work also includes additions to existing circuits in kitchens, bathrooms, outdoors and in other special locations. (See question 5 note 5.)
[h=2]Q4: Will all electrical work need Building Regulations approval?[/h]No. In general, notification will need to be given to, or full plans deposited with, a building control body only if the work is major involving one or more complete new circuits, and is not being carried out by an electrical contractor registered with an authorised competent person self-certification scheme.
[h=2]Q5: What types of electrical work are 'non-notifiable'?[/h]The following types of work are non-notifiable:
  • Replacing accessories such as socket-outlets, control switches and ceiling roses
  • Replacing the cable for a single circuit only, where damaged, for example, by fire, rodent or impact (1)
  • Re-fixing or replacing the enclosures of existing installation components (2)
  • Providing mechanical protection to existing fixed installations (3)
  • Installing or upgrading main or supplementary equipotential bonding (4)
  • Work that is not in a kitchen or special location and does not involve a special installation (5) and consists of:
    - adding lighting points (light fittings and switches) to an existing circuit (6)
    - adding socket-outlets and fused spurs to an existing ring or radial circuit (6)
[h=4]Notes:[/h](1) On condition that the replacement cable has the same current-carrying capacity, follows the same route and does not serve more than one sub-circuit through a distribution board;
(2) If the circuit's protective measures are unaffected;
(3) If the circuit's protective measures and current-carrying capacity of conductors are unaffected by increased thermal insulation;
(4) Such work shall comply with other applicable legislation, such as the Gas Safety (Installation and Use) Regulations;
(5) Special locations and installations are listed below;
(6) Only if the existing circuit protective device is suitable and provides protection for the modified circuit, and other relevant safety provisions are satisfactory.
[h=4]Special locations and installations (5):[/h]
  • Locations containing a bath tub or shower basin
  • Swimming pools or paddling pools
  • Hot air saunas
  • Electric floor or ceiling heating systems
  • Garden lighting or power installations
  • Solar photovoltaic (PV) power supply systems
  • Small scale generators such as micro-CHP units
  • Extra-low voltage lighting installations, other than pre-assembled, CE-marked lighting sets
Note: See Guidance Note 7 which gives more guidance on achieving safe installations where risks to people are greater.
[h=2]Q6: How will Part P apply to DIY work?[/h]Part P will apply to all electrical work in dwellings, whether carried out by professionals or DIYers.
Some DIY work will require the submission of a building notice to the local authority and the payment of a building control fee.
Some minor electrical work will not be notifiable (see above). Examples include adding a lighting or power point to an existing circuit, adding a spur to an existing circuit or replacing a light fitting.
[h=2]Q7: How will compliance with Part P be enforced?[/h]Failure to comply with the Building Regulations is a criminal offence and local authorities have the power to require the removal or alteration of work that does not comply with the requirements.
[h=2]Q8: What extra costs will be imposed on electricians?[/h]The annual cost of joining a Competent Person Scheme should be negligible, when spread over the number of jobs undertaken during the year.
[h=2]Q9: Local authorities will require more resources to cope with the extra work - where will these come from?[/h]There should be no additional financial implications for local authorities. The money to pay for additional Building Control Inspectors will accrue from building control fees.
Some local authorities will employ electrical inspectors, whilst others will operate a system of call-off contracts.
CLG require that the joining and inspection fees set by the scheme operator are sufficient only to cover their costs and allow future development of the schemes.
[h=2]Q10: Many electrical faults are not caused by bad workmanship, so why bother with Part P?[/h]In the Regulatory Impact Assessment, the Government estimated that around 30% of electrical accidents could be prevented through regulation, and that this would justify bringing electrical work in dwellings under Building Regulations control.
[h=2]Q11: Won't Part P simply drive more work 'underground'?[/h]The Regulatory Impact Assessment considered the question of whether regulation would result in more unsafe work. The Government does not consider there is any evidence that this will be the case.
[h=2]Q12: What will be the benefits of Part P?[/h]It is expected that bringing electrical work in dwellings under building regulations control will reduce the number of deaths, injuries and fires caused by faults in electrical installations. It is expected that nationally Part P will lead to an improvement in the competence of electrical contractors and to an improvement in the overall quality of electrical work.
http://imageceu1.247realmedia.com/0/------/Elec_FaradayCenter_July2012_v1/FaradayCentre_May2011_120x240.JPG
http://imageceu1.247realmedia.com/0/------/Elec_Brother_July2012_v2/120x240_June_2011.gif
Anyone can carry out electrical work,provided they notify,notifiable jobs to LABC, pay the fee or if Part P registered, do it through the scheme provider. If not a scheme member, you pay LABC the fee and they should send someone to inspect during installation and test afterwards(which they rarely do in my experience!), BUT!!! the LABC should provide this service INCLUSIVE OF THE NOTIFICATION FEE.
When LABC instructs someone to inspect and test, it is NOT to the cost of the Homeowner
Been through all this before I was part P registered. The notification of electrical work is a different fee to that of other work, and so unless requested at the time, wouldn't be covered by another building notice.
Although it sounds like (for once) they are sticking to the letter of the law, you are being told exactly what I was... Unless you notify and pay the fee for the BC officer to pre-inspect, then post-inspect, any electrical work must be signed off by a competent electrician who is part P registered. It is irrelevant what your qualifications are (it does state this in the electrician's guide to the building regs).
All that said, if it says in black and white that your notice covers specific electrical work, then you are covered, and they should have already been out for the initial electrical inspection.
Please don't shoot the messenger here, as I think it sucks, considering what so many cowboys get away with...
you are correct as regards purely electrical work. however, where a project has been subject to planning, LABC have already been notified and paid the appropriate fees. it is then at their discretion whether or not to accept a cert. from a non-registered sparks. if they want to test/inspect, then that is at their own expense
just to update you all looks like i'm getting my wallet out and paying a local electrician to test and do a pir on my electrics on my extension, been into see bci today and even if your qualified you can't do electrics on my own house even with paid building regs as you have to be registered. whats done it is people only with the 2382 saying there a qualified sparks and when they've done the work look at building control and say i can't test or do a cert so it opened a can of worms and to be fair he was clued up on what an electrician qualifications are and if he could would accept mine. oh and i'm not paying there inspection fee i've got a local plus cheaper sparks to come and check my work
No it's still in the 2010 doc page 12 I think , at the Councils expense . Download the doc it may save you a few quid.
For what its worth, my LABC specifically asks in the building regs application if electrical work will be carried out by registered contractor or not. If not, the cost is about £250 higher as they arrange it.
Reply to building control fee for electrical work even though its my job in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As per Part P of Building Regs, once electrical work is performed by a registered competent person, the installation certificate needs to be given...
I am writing to express my strong interest in joining your esteemed organization as I embark on the next phase of my career in the field of...
Hello, I understand that from the 15th of June testing and commissioning of vents and fans is now compulsory and that also since last year any...
4K
A long time lurker this is my first post. By way of introduction I have an interest in automation and smart homes - principally Loxone and Shelly...
