- Nov 26, 2012
- 330
- 126
- 118
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
- Business Name
- Udell Electrical Services ltd
Hi There
I have a customer who has a large mirror in her dressing room which she would like the theatre style make up mirror show lights installing all the way round the mirror. I have suggested to install 2 separate fittings either side of the mirror. these are off the shelf and saves me the hassle
The customer said she would prefer that the lights go all the way round the frame so that leaves me with the problem with how to achieve that. I wondered if anyone has had to do this and whether anyone had found any kits of parts that I can use to make this up.
At the moment I'm thinking of installing 2x2 white plastic trunking with some lamp holders in around the mirror. Would like to use LED to keep the heat down especially as id be using plastic trunking. Low voltage LED would be better incase one of the lamps get broken.
any suggestions would be greatly recieved
Cheers
Cheers
