Discuss Cable reeler help needed in the UK Electrical Forum area at ElectriciansForums.net
I personally, thought those things were a load carp, they were awkward to lift and move around and often collapsed! Also if you were pulling cables off the the drum to a high up place, as the drums got lighter the bar would lift up:mad:
Best cable reeler I used was made from 25mm metal conduit and 2 angle boxes!
Cheers for stating the obvious captin clever, dya know never even thought of repairing it..
This one is old bent and worn. I don’t want to try repairing an already tired item to be used daily. I was looking to replace it with a younger model
That’s no way to refer to your wife! ;)
Reply to Cable reeler help needed in the UK Electrical Forum area at ElectriciansForums.net
Evening all, Got a vent axia TX6 6” fan I need to replace. A like for like replacement is around £500, client is asking for a cheaper option...
I need an intermediate dimmer module for the BG nexus switch, but I can’t seem to find any? Any ideas where I can find one?
Evening all, Installed many extractors, but this is a first for me. Customer wants the fan vented out through the soffit, with an inline extractor...
Hi all, Got to look at a job where the builder has cut through the underfloor heating mat and it’s gone right through the heated cable. Not...
Hello fellow sparks, I’m looking to do my testing and inspection course which starts on the 30th of April, but I have not got much testing...
