M
markthespark
Im at Soho in the west end, think the nearest station to Aldgate is Whitechapel. Whats his name? Only know a couple of lads there.
I think you know what I meant
OK darling, I'll 'man up' as you call it.Ipf what's the point in that?? Man up and explain
Dragging us into Part pee again ? Can't be bothered....crapping and peeing everywhere.should be described as competent registered approved persons schemes. or CRAPS for short..
The letting agent said in an email. The electrician I sent round has turned off the circuit breakers until he can diagnose the fault – it’s important that they do get turned back on. If Mark goes round to do the work he needs to have a current certificate to say he is NICEIC qualified and in date, otherwise if something happens then you will be in serious trouble.
