Discuss Can I use one positive/negative/ground for more than one outdoor light setup? in the UK Electrical Forum area at ElectriciansForums.net
I need to figure out what gauge the wiring is on the current light so I don't mix the wrong gauges yeah?think if the existing cable can handle the extra load and they're all fed from the same breaker. should be OK. ( USA codes may be different from over here).
I don’t see why not because that’s what I did. I come out of my back porch light and installed wiring for 2 LED flood lights and my existing porch light works all of them with no problemI am wondering if it's fine and safe to use one wiring setup that already exists for my backdoor wall light and add a second one in the far back using the same postitive/negative/ground cable?
Reply to Can I use one positive/negative/ground for more than one outdoor light setup? in the UK Electrical Forum area at ElectriciansForums.net
