Discuss CCTV add on, options? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all,
Haven't done CCTV but customer asked me to take this out for him on various cameras cameras are rusty has hell so was going to put it up at my home
I'm asking if or what camera's will work with it also can I do it in CAT5.
and can I connect to a app to me phone.
Cheers
Grand
It looks like you have eight camera inputs on BNC connectors there - you'd need to use a suitable video cable rather than CAT5 I think.
Looking at this unit on Amazon, the spec says you can view remotely from your phone.
You can use any camera with a composite video output, the Floureon might not be the very best but for the price of a couple of cameras and a bit of cable you'll have functional CCTV which is very usable.
Try the old cameras but even cheap new ones are likely to be much better. Definition is better and the built-in IR LEDs are loads brighter than they used to be.
Reply to CCTV add on, options? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi. A client has asked for a home security system as part of a rewire. It occured to me that I'm never installing these only ripping them out...
Hi All, so I have a outdoor cctv camera that you plug in - I'm thinking of attaching this to the soffit and going into the loft from there (very...
Hi all. I have just set up a WiFi CCTV camera (SimShine Alloy 1S) which appears to be working as it should - very good image and sound quality...
I bouught a Nissan Townstar EV and have found what I consider a theft problem All previous vans I have had allowed the driver to enter and exit...
Hi Guys Time has come where we do actually need to start installing these. Few new builds coming up where is now a requirement. Done the course...
