Discuss Ceiling light wires in the DIY Electrical Advice area at ElectriciansForums.net
Rich6926
So I received my Wayfair light today - it’s a six light semi flush ceiling light.
I fitted it however only 4 out of the 6 bulbs lit up (all bulbs rotated and all work so not bad bulbs).
the wiring in the ceiling is a standard end of line 3 wires - live/ neutral/ earth.
the light has 4 connections;
Earth - green yellow
Neutral - x3 blue wires going into 1 junction
Live - x2 black wires going into 1 connection.
great so I wired these up with the ceiling wires.
As mentioned only 4 of the 6 light bulbs worked.
the 4 th wire is a single black wire - it has a red end cover and a label saying earth -
This totally blew my mind so I ignored it,,, any ideas what this is and should it be connected or have I just got a faulty light40D6FA22-4FBA-4191-8492-94E7FED2F494.jpeg
It appears the black should not have that earth tag on. It is possible that black is the other live so it can be switched at partial or full brightness but that is an assumption. What do the instructions say.
It’s a Wayfair special with very basic instructions ,,, more info on how to clean it
Put your live into the single black with the earth tag on lt and see if the other lamps function. If they do you need a link across the two terminals for the blacks.
Excellent,, I will give it a go later - that’s what I was thinking ?
Reactions: DPG
It is Polish.
Przewod pradowy means power cable.
Klasa ochronna means protection class.
Przewod ochronna means protective conductor.
Reply to Ceiling light wires in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
