Discuss Certifying Submain using niceiconline in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Bellendian
Hi, trying to work out how to put in figures to certify a sub-main install from origin to consumer unit using niceic online software...Tests all done but can't figure out how to make it look sensible for the certs!
Presumably there is a fused switch.
EIC with supply details at above and outgoing circuit (sub main) as final circuit details ....with a bit of an explanation as a note.
Cheers, I've got 2 of these to do, 1 was a replacement sub-main only, the other a switch/fuse plus db and final ccts.
Sure just writing things on paper forms is easier!
I've been playing around and seems that if I create a "remote board" rather than a "distribution board" then I can put in the info I need and it will display properly when the whole thing is complete....
There you go.....not so much of a bell end then, ian;)
Reply to Certifying Submain using niceiconline in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
As a non-electrician (I make the tea in the forum imaginary office, I think the tea is real though) I wonder, is there a way to avoid a...
NAPIT Certification Scheme NAPIT with more than one operative
Hi Guys Hope this is in the right place... I have recently joined NAPIT and had my assessment. We are a limited company of two qualified...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
Aside from every screwdriver in the universe, I wonder what the most creative mis-use of a tool you have encountered is. I'm sure this example can...
4K
