Discuss christmas lights on leisure battery, charged by panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
N
Noddy67
Hi,
Got a few panels left over and wanted to see if I could power my outdoor LED's using Solar, but not sure on the charging issues for the leisure battery.
Can I use a panel with c30v MPP panel to charge two 12v batteries in series? Near enough? Is there a risk of overcharging?
Anyone?
Regards
R
Hi, assuming you mean 12V lead-acid batteries; a fully charged battery is about 13.8V, so you need a voltage regulator to limit voltage to say 28V (2 x 14V), otherwise the batteries can start to gas (electrolyse the water) after being fully charged. That and a diode so the battery can't discharge through the panels (possibly the panels have one already) should do it - a fuse in series wouldn't hurt if all else fails.
Reply to christmas lights on leisure battery, charged by panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Good morning all. Before I start I am not an electrician and am relatively new to this topic. Current set up Axpert 5.5 Kw inverter, 7 x 420...
Hi, My camper has a new 12v battery and I have wired up a split charge relay with a 100 amp blade fuse near van battery and a 100 amp blade fuse...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
I currently have solar array and was going to purchase Shelly EM to monitor Grid in/out and solar production. So far so good. But I also plan in...
