Discuss Coffin DNO cutout in the UK Electrical Forum area at ElectriciansForums.net
O
omega
Hi all, just wondering if anyone can help with this little question? I'm just about to do a full rewire on a domestic dwelling and have come across a DNO cutout I've not seen before. It's an ISCO cutout with a fused Neutral. I've done some checking on the forum earlier and from what I can gather, these can sometimes contain asbestos? My question is this; does the cutout need changing by the DNO in order to certificate the job? Obviously the details of the cutout need to be noted on the Electrical installation cert, however, I'm not sure with this one. Any help would
be much appreciated. I've attached pic of the said culprit.
Yes get DNO out, you can't have a fuse in the neutral anyway, never mind the asbestos. Tell the DNO that it has been smelling of burning electric, and the homeowner has been complaining about lights dimming or some other excuse, they should bung another one in with no problems. But whatever happens don't you bugger about with it.
Cheers………….Howard
I dont think the neutral is fused as surely that would make the iron casing the same size as the live casing???? I think its just for connection purposes. I could be very wrong though. Either way, I would do as others have said and ring DNO, they will/should change it for free.
Jay
as above. and if i'm right, it's got a BS951 making a TN-S, just visible at the bottom of the pic. DNO will replace the cut-out and fit proper earthing.
All donations gratefully received! If you can save the head / cutout intact, drop me a line by PM or email and I'll sort out with you to post them or pick up or whatever. Asbestos isn't likely to be a problem unless you start smashing the fuse carrier to bits, or there might not be any at all anyway.
Always a few beers up for grabs, for anyone who gets us interesting old stuff, especially DNO's gear which we are very short of.
And then there was the loaded hearse driving up West Street on its way to the crem.
Now West street was quite a steep hill and was paved with cobble stones which could be quite slippery when wet and on this day it had been raining.
Anyway, about half way up the hill the driver missed a gear and the hearse jerked, the back door flew open and the loaded coffin slid out and proceeded feet end first like a bob-sled down West Street.
At the bottom of West Street, there is a T-Junction and the bob-sled ( sorry, coffin ) wasn't going to give way to anything and shot straight across, up onto the pavement on the opposite side. It then smashed through the door of the chemist shop and came to a sudden stop when it collided with the counter.
The coffin lid then flew off and the corpse - due to the sudden stop - sat bolt upright and said to the very startled young lady behind the counter .......
.................. excuse me Miss........
............. Can you give me something to stop me coffin?
( Ok .. I'll slide back over to "the other side" and irritate them for a bit )
Reply to Coffin DNO cutout in the UK Electrical Forum area at ElectriciansForums.net
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi All, hope you can help I’m a competent DIYer and have Dimplex Storage Heaters (XL24N) the advice I need is that I ordered a new Thermostat...
