So, you've hired an electrician who is also a builder to carry out remedial works. This guy came recommended by your painter and decorator. So far I see nothing wrong with what you've done.
The damp issue is not electrically related so this is the wrong place to discuss it, having said that as the Electrician/Builder (E/B) has represented himself as competent to carry out this work then he is responsible for it being to a reasonable standard which it clearly isn't. Again I can see nothing wrong in what you have done.
This assumes that the work done is by his recommended method using his recommended materials. If on the other hand he is carrying out works to somebody else's specification then that's a different situation.
To clarify, if you have instructed the E/B to board out the wall and make good the electrical issues and not specifically mentioned that there is a damp issue to resolve then you're on sticky ground.
This is quite typical in that work is often tendered without a clear specification in the hope a contractor spends time, effort and money diagnosing problems and proposing solutions.
From a contractors point of view this is frustrating as many unscrupulous clients then put this work product out to tender looking for the lowest possible price.
The electrical issue you've presented us with is trivial and easily remedied and I don't believe is the cause of your conflict, rather an attempt to add supporting evidence to your defense of the E/B's claim.
Other than possibly not being competent to source these kind of works you haven't done a great deal wrong if, and it's the big if, you've told us everything.
I'd personally be reviewing all my communications and making sure all details are correct and that the E/B has definitely failed to deliver against what is written, not what you think should have been done.
Also I'd be communicating with the E/B and attempting to resolve the issues by mutual consent.
Oh and change career, estate agents are scum and it should be held against you in court, in my humble opinion.:p:p
Personally I hope he keeps posting. I'm sure he will as he seems to be like a dog with a bone.
Is that a known fact or assumption?
I wrote this message out (below)
yesterday at about 3.50pm.....and forgot to post it as a reply. Unfortunately, I've just spent a wasted 30 mins reading some usual bunkum, as a result. Maybe I should have recognized signs of an estate agent/DIY builder/trainee electrician.....and even the fact there was going to be a court case involved.
''It looks like someone's after a bit of vindication...…..again!
A load of Maarrd and minor points when all he needs is someone on site to inspect and give a good idea of how the situation stands. He's after free info....as long as it concurs with his mindset.''
One of the top 5 posts ive been invokved in this forum, the fact the estate agent is on an electrical course is a classic.
Wonder what course it is, would be amazing if hes a boil in the bag.
Reactions: JOURNEYMAN
If he is, he needs lancing.
He must have big balls to admit he’s an estate agent on public forum.
I’m gonna keep posting just to pish him off
OP - This is a witch hunt, nothing more, nothing less. From the photos you have shown there is nothing electrically wrong with that work at the moment - but clearly you will cherry pick responses to suit your agenda. All I can say is good luck to your tradesman, I hope he gets paid for the work he has completed.
thank you for response.
Builder/electrician specified.
i have paid the B/E for the work done to date and over (33% of the job)
The b/e has been overly agressive and threatening. Had breached gdpr too
and no I am not scum - that is disgusting. Have you been taken to court by one?
i can now see exactly why the general public despise tradespeople with the absolutely disgusting comments in this thread alone.
if you have had difficultly with many customers perhaps its you who should change your attitude
Why has the work not been completed then? Did you ditch the builder/electrician or did they walk?
Reactions: GMES
confused by statement by NICEIC that this ok? Electrician compliant as circuit not energised. Can anyone tell me how NICEIC can make statement like this and assess wiring ok when they haven been to my house to inspect
see attached the work left like this on Aug14th and I cant get it removed until somebody says it non compliant
1. What is the statement from the NICEIC can we see a copy with addresses blanked out?
2. What makes you convinced that this is energised?
3. why does this need to be removed?
4. There is no mention in your opening post regarding court case what is the electrician/builder taking you to court for?
That's priceless coming from an Estate Agent ! However also a rather venemous statement, why then do you aspire to be an electrician ? Perhaps to carry out EICRs and/or remedial works on your 'managed' [and I use that word optimistically] properties ?
You can leech even more from landlords then ?!
A tradesman with integrity is always welcomed by a decent customer, and appreciated too, the key word is possibly decent....
comfused by NICEIC statement
NICEIC Certification Scheme
Certification NICEIC, NAPIT, Stroma, BECSA Forum
hoitytoity,
GMES,
