Driver
Hi all,
I'm about to start a complete refurbishment/extension of our house and need some advice. One of the things I've been thinking about is the electrics. I want to make sure it's done right and the setup is adequate for our current needs with some element of future proofing.
Starting with the CU, the contractor is recommending a 20-way split load which will supply 5 bedrooms, 3 bathrooms, a utility room, a large kitchen/diner/lounge, a living room, a play room/home cinema and a server room. There will be LED spots throughout and the server/play room/HC will have have servers/PC/amps (high current) for AV distribution.
In my previous house, when switching on amps or anything high current, we would get a dimming or flicker of the lights. I'm guessing this is because of the old CU and wiring setup but an example of things I want to avoid with the new rewire.
So my questions:
1. Is a split load CU ok or should I spend more on a RCBO? I've read Crabtree is a good brand, any other recommendations? Model's or links would be helpful.
2. We are having dimmable LED spots throughout. In my previous house the dimmer switches would buzz and often bulbs would blow. Again I'm assuming this was down to the old wiring and dimmer switches but want to avoid this with the new rewire. Is there a 'best practice' wiring diagram to show how the lights should be wired? If we have any issues in future, I want the setup to be easy to troubleshoot for any electrician.
Apologies for the long post and thanks for reading!
So my questions:
