Discuss Connecting wall mount in the DIY Electrical Advice area at ElectriciansForums.net
spjonesuk
Ive bought a atf600 wall mount with transformer attached. Details on transformer are input 230v output 4.2v 600ma. Question is I have a unused fused spur where I want to put this could I connect it to the fused spur if so what fuse would I put in the spur.
Many thanks
Yes, and 3A.
The power module can be fitted in a 47mm deep plastic back box behind the programmer wall bracket.
If you're not planning on doing that, the module really needs to be in an enclosure to provide adequate insulation for the mains connections.
Yes, and 3A.
What size cable would i use to supply the transformer from the fcu?
Reply to Connecting wall mount in the DIY Electrical Advice area at ElectriciansForums.net
Evening all, Iā€™m looking to install an outside light as a spur from a socket on a ring main. There is already a spur from this socket supplying...
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hi all, hope someone can help šŸ˜Š. I am looking at running a transformer extension lead behind my dot dab plasterboard wall. My wife bought a Led...
