Discuss Consumer Unit Change in the UK Electrical Forum area at ElectriciansForums.net
Otherwise something is bound to come back and bite you on commission.
I find it helps to do some identifying at the same time.
Reply to Consumer Unit Change in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
