- Reaction score
- 17,087
.....Okay then what do you personally think it is?
A contactor as that's what the part number is listed as by the manufacturer.
Discuss contactor rating in the UK Electrical Forum area at ElectriciansForums.net
that said you can get clip in auxillary contacts.I didn't realise a contactor could be switched using Normally open Or normally closed contacts like a relay can be switched, I thought they were coil controlled?
Do you have much experience with automation and control gear?A contactor as that's what the part number is listed as by the manufacturer.
Interesting thread, my thoughts are that a contactor is either open or closed and used to switch on/off and for switching high loads.
whereas a relay is for control switching with a common and n/o n/c. So a relay can be used as a contactor but not the other way round.
So if I'm right, the picture is of a contactor as it has no common, although it has independent n/o n/c contactors it cant switch from one to the other.
Reply to contactor rating in the UK Electrical Forum area at ElectriciansForums.net
