Discuss Convert washing machine isolation switch into a plug? in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, I have two isolation switches above a kitchen workcounter. They currently turn off the power to a pair of unswitched sockets which are hidden in a cupboard. They were previously used for a integrated washing machine and tumble drier we had plugged in, which we removed. As the plug is no longer of use, I'd prefer to convert the isolation switches above the worktop into a plug which can serve a worktop appliance such as our coffee machine.
Is it possible to convert the isolation switch into a plug? The fuse on the far right is for our boiler and would not be touched. Thanks16736959625692481939995060837984.jpg
Yes. It will be possible.
Likely on the same circuit as the sockets in the kitchen, unless it’s on its own dedicated radial circuit.
Either way, it’s suitable to be changed to a single socket.
Hi thanks for confirming, I'll look into how and consult a local electrician to do the work now I know it can be done. Thanks again
Reply to Convert washing machine isolation switch into a plug? in the DIY Electrical Advice area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
Hi, I am not an electrician and looking for some electrical advice. We have had a new electric roller door installed at our warehouse. The door...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
