Discuss Cooker control switch needed or not? in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, just a quick question: I appreciate that if you're installing a cooker, then there ought to be a cooker control switch fitted within 2m of the appliance etc., no probs. However, what's the deal with a separate oven and hob? I've got these to install soon, and it's my intention to feed each one separately, but I admit I'm a bit confused as to whether I still needed to put in a CCS (no socket) controlling the hob say? Any advice would be much appreciated!
Aye, forget to say, feed it from the CCS/Isolator.
Personally, I wouldn't worry too much about the 2m 'rule', locate it somewhere nearby and convenient.
Cheers for that mate, much appreciated. The client wants to use a grid switch arrangement for all the kitchen stuff, and I've seen engraved grid switches which look nice, but not sure if they'll take 6mm cable, I'll have to check that out. If not, it's back to the usual big red switch!
Good luck putting 6mm into a grid plate!
What rating would a grid plate/switch have. I haven't used them yet, but I doubt they are 45A, are they?
same as he said^^ about what he said^^^ about what he said^^^^and others.
Looked up the specs for the MK switches, and they do say they will accept one 6mm cable, BUT I've not had direct experience of them, so don't know how awkward that size cable would be to wire up in them?
Reply to Cooker control switch needed or not? in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
I hope this is the correct thread. I have to replace the main oven selector switch in a Smeg A4-5 cooker. I can't find a proper service manual...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi, The current state of play is a standalone combined oven and hob supplied by single cooker circuit with 40A RCBO, 6mm cable, isolated by cooker...
