C
CenterSparks
When using red through crimps on .75 flex, with enough force should I be able to pull the cable out? I can't seem to get a tight enough crimp, it takes some force but I can pull it out. Is it the crimper?
no, it's the user. red crimps are for 1.5mmsolid or strandedcable. not flex and definitely not .75.
Crikey Tel, that's a debate starter right there ain't it?
OP, can you use wagos/lines etc instead?
jury is still out on crimps and solid. personally, i use the line products push-in , in line connectors.
Yes....Are red crimps not for .25 - 1.5 cable? That's what it says on the crimpers.
please put up a link for , in line push in connectors for 2.5mm cheers
theres a lot of stuff being said in here just now about `pullin it` and `crimpers`....
just a thought guys....
i hope that wasn`t an open invite there geordie....Can I do you now Sir? :winkiss:
to crimp cables is just wrong
boys are taught/advised to do it by ----ers
