Discuss Cut-Out Fuse Question in the UK Electrical Forum area at ElectriciansForums.net
harv
Newbie Question: I know theres loads of posts about this topic, but IM due to change a consumer unit for a customer and had told them to contact their supplier to get an isolator switch fitted(they are having a smart meter fitted as well) and the supplier has said thats the DNOs responsibility. the DNO have told the customer that they are happy for me to cut their seal, remove the fuse change the CU and then re-install the fuse, and that i don't need to re-seal the cut-out because they are having a the smart meter fitted within 28 days of me completing the job.
Any one come across a policy like this before? I know SSE (the DNO in question) can supply temporary seals to contractors, but i cant get hold of the depot to request some and the customer service centre couldn't do anything other than give me the phone number for the depot(which is what id been trying)
any advice would be great
I'm rather surprised at the DNO's response, but as they have said you don't need to reseal the cut-out, why are you worrying?
Just slightly concerned that with the customers energy supplier fitting a smart meter after I've been to change the CU that the finger could be pointed at me for the fuse not being sealed. Are they really concerned about fuse seals or are the meter seals more of a concern for them?
Sse are one of the good dnos for this.
They usually provide stickers as temp seals.
I use my own metal seals and crimps to reseal when done.
As long as it's single phase domestic setting. With no loads and cut out in good condition then sse will permit you to pull the fuse if you are in a scheme.
Im registered NICEIC, and as i mentioned, i cant get hold of the depot to get temp seals, but they've said over the phone they are happy for me to pull and not worry about re-sealing it as the supplier are fitting a smart meter within the following 28 days. should i be concerned or just do as they've said?
Ask for it in an email then.
I have done and am waiting for them to get back to me, Just wandered if i should be concerned or if I'm over thinking it because the meter is being changed after I've been there and its me who will have cut the cut-out seal.
I've been lucky over the years, most haven't been sealed ?
DNO's in my experience are fine as long as your registered with the NICEIC.
They will allow you to pull the fuse, and send someone around to re seal afterwards.
IF your NAPIT they will send a SWAT team in. ?
It does annoy me when they fit smart meters but cant be arsed to fit an isolator at the same time.
Deffo ring the DNO if smart meters are installed, or your customer will get a call asking if theirs something wrong with there supply. I prefer to fit my own seals once finished anyway, just seems the right thing to do.
IF your NAPPIT they will send a SWAT team in. ?
Thanks for this, sounds like all should be okay, will look at getting my own seals because as you say seems like the right thing to do and gives piece of mind. I Was just worried that the old analogue meter was changed in 2006 and the fuse was sealed then and has remained that way since and don't want any grief from them after the meter change happens post me being there if i was to leave it un-sealed.
You are over thinking this... if you have a brother label printer you can get security tape and put this on, better than a paper label and once removed cant be re-applied.
Reply to Cut-Out Fuse Question in the UK Electrical Forum area at ElectriciansForums.net
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
I have an new set of circs here... Landlord in Cyprus EICR needed in empty flat. No credit on meter. Need power for Ze (TNCS) and RCD test at...
Hi Everyone, I have a faulty smart meter, its broken since I moved in and I am putting all my effort to fix this, I am a tenant though. A...
My customer has had a completely new supply installed to his garage. The DNO has not put a fuse in the cut out though. I'm guessing he needs to...
