Discuss Cut-Out Fuse Question in the UK Electrical Forum area at ElectriciansForums.net
thanks all of you, i thought i might have been overthinking it, but just wanted some other opinions.you'll only get grief if there is evidence of energy theft. just get the customer to shut down his cannabis farm for a couple of days. ??
Tis true, but we have all been guilty of overthinking things. Especially if you keep reading that ruddy light blue book. ? Heaven forbid!! Do it to often and you'll turn into an NICEIC assessor ???You are over thinking this... if you have a brother label printer you can get security tape and put this on, better than a paper label and once removed cant be re-applied.
thanks for reassuring me, i thought i was but as i said, just kept thinking about it and wether i was doing the right thing.Tis true, but we have all been guilty of overthinking things. Especially if you keep reading that ruddy light blue book. ? Heaven forbid!! Do it to often and you'll turn into an NICEIC assessor ???
Just always and I mean ALWAYS do an IR test on your CUs main switch (BEFORE installing any tails) so you know its good before putting that cut out fuse back in. NEVER rely on it being in the off position, because they can be faulty. And fitting a 100 amp cut out fuse back into the carrier with a dead short on the end of it isn't for the faint hearted. I spoke to a lad about his experience when in A&E once. He was still shaking after they had bandaged his hand up ?thanks for reassuring me, i thought i was but as i said, just kept thinking about it and wether i was doing the right thing.
Maybe some bicycle clips as well.Brown trousers can be an asset as well.
Reply to Cut-Out Fuse Question in the UK Electrical Forum area at ElectriciansForums.net
