Discuss Cut through the sheathing of cooker cable. in the UK Electrical Forum area at ElectriciansForums.net
wago do a 40A push-in connector that takes 6mm cable. cooker will never pull 40A as long as it,s got a door that opens.
There is no need for tape, either self amalgamating or insulation tape. Use a standard 30a JB, carefully strip back the outer sheath just enough so that the cores will pass through the 3 terminals, do not cut the cores, just clamp them in the terminals. Make sure the sheath just enters both entries of the JB so no basic insulation is exposed. Best to fix the JB to a batten under the floor, and secure the cable either side of the box with a clip or two. As the cores are not cut this is not a joint and so does not need to be maintenance free, it is simply an enclosure. The bare cpc could be taped if you feel the need, I wouldnt worry.
How would one fit a terminal box over wires that haven’t been cut. That just confused the ---- out of me ?
you take the screws right out of the terminals then slot the conductors in. then replace screws.
and there's no need for cable restraints as the uncut cable cannot pull out of the terminals.
i realises this afternoon I posted. Then I edited my reply. Thank you
I know I’m hijacking my own thread but is there a tool that removes the grey outer shield on the cable? I only have such a tool to remove the blue and brown shields last time i used a Stanley and this happens
should be more careful then. o_O o_O o_O. use a stanley or electricians knife to cut along the cable central, i line with the earth. then tease sheath away from conductors and cut away. try not to nick the inner insulation . it' won't hurt like a finger but could be dangerous.
Reply to Cut through the sheathing of cooker cable. in the UK Electrical Forum area at ElectriciansForums.net
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
Hi All, We've recently moved to a new build where the HMDI cable for the TV etc. are pre-fitted in the cavity of the wall. One end of the HMDI...
Good afternoon, Sorry for the long post but can find answers to my questions anywhere. I’m want to replace my old cooker hood for a new one...
