Search the forum,
Discuss Cutting back boxes in plasterboard in the UK Electrical Forum area at ElectriciansForums.net
The Appleby ones with yellow lug pieces aren’t too bad. Only ones for me..when needed.
Generally prefer them over other makes, but lugs only allow for fitment in single board. No chance they'll fit double boarded walls without cutting away at rear board, so on those occasions I prefer 'lesser' brands.
Multi tool every time for me, but does not work on a solid flint wall with internal sand and cement render 🥴 then its a carbide tip hole saw followed with a hammer and chisel. 😱
Never heard of anyone trying to cut stone walls with a multi tool. I guess there's a first time for everything.
It works.
Ok… only a certain blade on a certain type of block… but if you’re lucky in that respect…
You can basically scrape the hole flat with a bolster chisel. No hammer involved… and make rawlplug holes with a plumbers old screwdriver.
Reply to Cutting back boxes in plasterboard in the UK Electrical Forum area at ElectriciansForums.net
Hey everyone, I'm trying to understand how to fit a metallic back box on a stud wall. Should it be fixed to a stud (on one of the sides) or is it...
5K
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hi, I wanted to slightly re-route a badly routed 6mm2 twin and earth flat cable, that leaves my utility room through the plasterboard, the wall...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Recently sorting out first fix for a loft extension for a friend and ran into a situation I don't often run into (I avoid new builds usually) In...
7K
