Discuss Dado Trunking in the UK Electrical Forum area at ElectriciansForums.net
R
Richard
Got an office to fit dado trunking around, Just wondering if someone has a magic number hight wise for the trunking as no office furniture is there yet. I could take an educated guess I know but just checking in case someone knows better.
Thanking you.
Desks are usually 3ft give a little clearance for plug flexes but no specific height i dont believe ... sometimes window ledges etc may pre-empt your chosen height.
TIP... check lids, bends etc - if they lip over the trunking then dont forget to allow a space if running up against a ledge or wall edge or your lid wont clip on.
Got a Local Authority spec. through to fit dado trunking in some offices. Their's state top of trunking 950mm AFF level in some offices and 1000mm AFF level in others.
If you haven't a specified height, then as others have said!
darkwood has pointed out an excellent tip that's very often overlooked! Bloody good advice IMO.
Reply to Dado Trunking in the UK Electrical Forum area at ElectriciansForums.net
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
I've come to a decision, I just cant do work anymore that involves mad stuff, for example today - 2 bed flat that's had fire damage, someone has...
Hi guys, I've got a job where I'm installing dado trunking on the floor of an office for sockets and data. Some info on job - In total I will be...
5K
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
