Discuss decision to make in the UK Electrical Forum area at ElectriciansForums.net
J
jamie s
i have been asked to install a rewire into a house including a new consumer unit. the customer would also like power run to a shed which i have never done before. my instinct says i would need swa as he doesnt want high or underground cable. it is only to supply a shed c.u for sockets and lights so am intrigued to find out my options from you professionals! any advice appreciated
and how many points will be in this shed?.....whats the intended use?.....whats the earthing arrangements here?....any water or gas extrainious conductive parts in this shed?.......check both earthing and bonding arrangements here first and upgrade/replace to the 17th edition standard before doing any work here....how longs the run from the origin of supply for this shed and the shed itself?....
3 sockets, 2 lights, man shed so prob radio and power tools, no water or gas but will double check. 10m run from supply to shed and 3m l, 2m h, 1m d shed.
so i would suggest a 16A MCB (for the outlets).....and a 6A MCB for lighting......need to know the earthing arrangements though mate as this will determine whether an s type RCD is required (for discrimination purposes)......
Oh lord... on your marks.....
But seriously. nothing to be afraid of. Plenty of guides around.. Check with your scheme provider and see what they advise..
TBH I would bury SWA, out of sight, out of mind. As you're doing a complete rewire, run T+E under the floor space if you can, adaptable box onto SWA and off to the shed you go. Buried looks a hell of a lot tidier, if not, is there anything for you to clip the cable to?
The key word I`m afraid is professionals. I take it from this that you dont consider yourself a professional which begs the question should you be undertaking any of the work in the first place?
are you qualified/ competent/ experienced to complete this work? Are you notifying this work or have you contacted building control?
I have noticed that these posts are becoming less frequently responded to by the regulars for good reasons.
To be honest, I suspect that if you were competent to be undertaking this kind of work, then there would be no need to ask this type of question as you would be familiar with the requirements for electrical installations BS 7671.
Hence I will offer no further advice unless specific and understandable questions come forthwith.
Get a registered and experienced electrician.
Reply to decision to make in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
