Discuss Designing with diversity on sockets in the UK Electrical Forum area at ElectriciansForums.net
I never said to just subtract 60% the figures are in the onsite guide,
Other ring would be at 40% (32 × 0.4 = 12.8A)
i just used what the OP had posted ie 40%.
Ive recently passed the design section on my apprenticeship & we we're tought that unless you can guarantee ie know for certain what is going to be plugged into the ring or radial then you go by the protective device rating & then apply diversity
Where did you study? And who told you that?
Now, I could probably knock 25A off the sockets and 3 or 4 off the lights but I cannot see for the life of me how this was ever signed off.
In general the standard of the install is quite good.
So you think the fuse will blow at 101 amps because it has got the number 100 written on it???
No. but we're not talking about an extra Amp or two.
Fixed loads alone are c.120A, all other circuits on and we're getting close to double the rating, and it may take me a few minutes to get to the incomer.
Edited to add the bold text.
There is no way that house is drawing 30+ kw of power. Common sense and arithmetic will confirm this.
Ps how much current does it take to blow a fuse that has got 100 written on it?
You are nowhere near double the rating of the fuse
I applied the OSG method to the 2 ring finals and 1 radial (32 + 40% of 32+16) and then applied 100w per light fitting to the lights and did the loads for the actual boiler and oven (plus 5a for socket) and it all comes in at 77a so just less than the 80a fuse so i will put that on the certificate even though 51 amps for the socket circuits is crazy haha.
Thanks for the help people not been on the forum for long but its proving really useful :):):)
100W per light fitting sounds chronically out of date to me, now we're well into LEDs now.
Quite an interesting test for you to try, check how much juice you use in a week or so, then average it out over 16 hours per day (asleep or out for 8ish hours). The size of the result may surprise you!
Exactly, my previous television was 1200 watts and the one I replaced it with is just 35 watts
Invest in a clamp meter. When you go to properties just check what load is being used by clamping the line meter tail. After a few jobs you'll start to build a mental picture of what a domestic property actually uses.
Agree a clamp meter will give you a massive insight into diversity and make you much more comfortable with actually calculating when it’s called for..
Reply to Designing with diversity on sockets in the UK Electrical Forum area at ElectriciansForums.net
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
