Discuss dimming led's in the UK Electrical Forum area at ElectriciansForums.net
The V-Pro dimmer linked will dim Inceptor max very well, not tried on the micro but no reason to assume it won't.
I'll be surprised if you can find any dimmer that will dim one of those LED filament lamps. I haven't yet, although I've not tried for a few months.
You would need to get a dimmable version of the LED filament bulb in order to be able to dim it, then I would expect that the V-pro might be able to dim that lamp but it would be below the minimum wattage of 10W, so a resload or such like might be required to up the load slightly.
Should work OK on 6 of the inceptor micro.
bright - 620 lumen - and dimmable to <1% using a conventional dimmer
should be OK i guess?
Reply to dimming led's in the UK Electrical Forum area at ElectriciansForums.net
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
The G4 110V 3W dimmable bulbs I purchased work with a dimmer. I can brighten them and dim them, but when I turn the dimmer off, the LED bulbs...
In this article, we discuss the running costs of different types of light bulbs in the UK. We compare the costs of CFL and LED bulbs and show how...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
