Discuss Do I Connect Clean Earth On Metal Switched Socket in the UK Electrical Forum area at ElectriciansForums.net
I’m replacing old plastic light switches and sockets for metal ones. I’ve gone with BG Nexus range but I’m a little confused as to whether or not I need to connect a wire to the clean earth connection. Looking at the wiring diagram it is not used. I know I need to run a fly lead from the switch to the back box but looking at the diagram there are two earth wires leaving the earth socket. One will go to the back box but where does the other one go to?
I’ve also read on a forum that I should run a link between the clean earth and the earth socket.....or do I just leave it empty.
Thanks in advance.
Then looking at the diagram for the double sockets has me more confused. The pic on the right I can understand but the one on the left is baffling. I know the 2 earths are linked with a bar so effectively one but can someone explain what the functional earth is on the left please
The second terminal is there so you can install extra CPCs for computer equipment, lots of carp about this online, but basically in your case forget all about it and connect your CPC to either terminal
Like spinlondons reply, and agree hense my comment about carp online
It is for circuits with high inherent leakage to earth and where the loss of an earth to a socket could create a hazard. For a ring final circuit which incorporates two cpcs (circuit protective conductor or earth) you connect one into each so the theory being both would have to fail for you to lose the earth. Nothing to concern you.
I have seen some FCUs, where there are two Earth terminals, which were not connected together.
I just figured they were faulty, but apparently they are used for clean earths.
One terminal is a parking terminal for the CPC, and the other connects to the load side earth so you can run a separate clean earth.
I'm sorry but you've lost me there......
Reply to Do I Connect Clean Earth On Metal Switched Socket in the UK Electrical Forum area at ElectriciansForums.net
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
