Discuss Do I need a certificate? in the UK Electrical Forum area at ElectriciansForums.net
Gingernut
Morning,
I live in a rental property and when I moved in I fitted an outside socket. Was an easy job as it was fitted at the other side of the wall to a kitchen socket so I just took it from the kitchen circuit.
The landlord has said he requires it registering and a certification providing.
Is this correct as it has only been fitted using an existing circuit?
Appreciate your help.
Don't think it is a notifiable job as it did not require a new circuit am sure someone will put me right if I've misunderstood that one though. I would say it he owns the property though he's perfectly entitled to want to see that any work has been done to a decent a compliant standard that may be where he's coming from on this one.
I believe it's not notifiable any more because it's not a new circuit but you do need some testers and a minor works certificate otherwise your still on a sticky wicket
Ok thanks. Just advise me what sort of cost that should be if I ask an electrician to do that for me. I don't know what that involves and don't want to get ripped off just to get a certificate. Thanks
Morning,
A MNW minor new works certificate is required, you have altered an existing circuit
Just a point of technicality..... as it's non-notifiable there's nothing to prevent the OP from producing their own MWC based on the model forms.
(I can hear the gasps from Somerset....)
As an aside it will be difficult to issue cert after the event, as the tester will need to see evidence of how the install was installed in the first place, that's how I see it anyway, others may disagree.
Reply to Do I need a certificate? in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Good morning, I'm in the process of a partial refurbishment which will involve the present kitchen being changed into a bedroom instead and the...
Hi Everyone, I had a new consumer unit installed in December 2021, the electrician said that he had more testing to complete and would come back...
