Discuss dry line boxs back to back? in the UK Electrical Forum area at ElectriciansForums.net
Can dry line socket back boxes be mounted back to back in a stud wall if its deep enough?
And if so do they need to have the fire seal installed?
I doubt the walls not a fire barrier as it only just goes up pasted the false ceiling but it is still fitted with fire rate double plaster board
Pink board is expensive about £5 per metre , so no way would a builder use 2 sheet thickness unless they absolutely had to
Hi - it sounds like a fire rated wall to me. And for sound insulation properties to be maintained the boxes should not be back to back too.
Reply to dry line boxs back to back? in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
Hello, My house has 25mm back boxes throughout, but I’ve noticed the previous owner has installed sockets and switches that seem to...
Hi Guys, I've completed rewires with hollow walls before and was able to use a dry line Box. No chance of being able to use them this time. I've...
5K
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
