Discuss Earth bonding for meters in the UK Electrical Forum area at ElectriciansForums.net
Maxine
Hi, I am just after some advice. I am having new meters fitted and been told they need to be earth bonded? I've attached a photo as my friend thinks this has been done but I need to know before I book an electrician, so any help is appreciated, thank you
You have what appears to be a bonding cable at the bottom pipe.
The size needs to be confirmed as adequate,the bond needs to be made before any intersection,yours is in the wrong position,also the "do not remove" warning tag is all but destroyed
Employ a sparks to put it right
Thank you. Was hoping to keep expenses down but looks like it needs doing.
It shouldn’t be any more than a call out charge plus a few £ for materials.
As above. The size of the bonding cable, and its continuity need checking.
This is the Electricians, what is that copper tubing for. Remember I’m from the USA and want to learn y’alls way of doing
gas pies. and meter. sod it ... pipes, not pies. the bit with the yellow tape is incoming to meter. the copper behind is from meter to boiler/cooker/ etc.
I don't deal with domestic works, although I am qualified to do so.
however I do know 2 different competent domestic (part p) electricians that could sort this out for you.
they are both based in tamworth, so not far from you.
they are both time served, professional electricians who I call on for any works that fall out of my preferred line of work.
if you are not able to find someone willing to help on the forum, feel free to ask for there contact details.
Thank you. I have someone coming to give me a quote tomorrow, so I am happy for some comparison quotes. It's not just this, I need a safety switch for a cooker hood the shower isolation cord doesn't work, the extractor fan in the bathroom doesn't work and the ceiling light in the lounge is loose
Apart from that the house is great! Think I may need to marry an electrician, it would be cheaper in the long run...
Not ready for marriage, could manage a quick affair maybe?
On a more serious note, if you want me to pass on details of 2 good sparks, just let me know.
Lol.yes please. For the quotes. Not the affair. I'm really busy at the moment
Going to sulk now (sleep)
Will post details for you 1st thing in morning.
P.s. thanks for the polite turn down.
At least I don’t feel too unwanted.
P.p.s don’t take me to seriously I am a fantastic spark but a poor lover!!!
I'm sure you're great. Don't put yourself down! Thank you, I appreciate your help.
The copper pipe is the customers gas pipework coming from the meter.
The corrugated pipe is the incoming gas supply to the meter.
The main bonding is the green and yellow wire coming out of the floorboards and connecting to the old painted gas pipe.
Our regulations require it to be connected on the meter side of any branches in the pipework, so in this case it is technically incorrect but in practice will perform its function perfectly well as it is.
Reply to Earth bonding for meters in the UK Electrical Forum area at ElectriciansForums.net
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
In my bathroom there is supplementary bonding of the bath, bath pipework, and basin pipework before it goes into trunking and exits unconnected in...
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
