Search for tools and product advice,
Discuss Earth fault loop high - DNO say problem is next door? in the UK Electrical Forum area at ElectriciansForums.net
A
alanl
I fitted a new circuit, upon testing, the EFLI was 1.29 ohms on a TN-S system.I rang up the DNO for advice, and was told that is an emergency, we'll be there within 2 hours.There was no point me hanging around, so I went to my next job. I caught up with the houseowner today, and asked what happened. She said the DNO man did some tests, then cut off all power to the street, then did something in the next door house, and everything was fine then.What could be the problem in next door that affects the EFLI?
probably the supply comes from next door....from out of the service head next door ....and into the service head here....just because there was a head here doesn`t mean the supply isn`t shared.....quite common on terrace houses and some semis.....
Reply to Earth fault loop high - DNO say problem is next door? in the UK Electrical Forum area at ElectriciansForums.net
The other night, neighbour knocked my door. She said she'd gone to use their outdoor tap, and she thought she'd got a shock. Went and had a look...
I work in the events industry which works under 7909. This assumes that someone qualified 7671 etc has tested the distor's and designed a system...
Probably going to get slated for not knowing/doing something wrong but here goes!! So, been asked to do a board change for a customer, when I...
4K
Hi there, I’m just hoping someone could clear something up for me at all. I’m just working my way through some test questions and I’ve come across...
Morning chaps, A bit of background. Finished a job yesterday, it was a bathroom install for the council on a private job. So with these they are...
