Discuss Earth Loop too High in the UK Electrical Forum area at ElectriciansForums.net
P
Peter Hartley
Hi there Guys
I am new to the UK and have just a quick question. When your earth loop reading I too high in the UK, can you proceed to do an earth/neutral bond before the consumer main switch or do you have to contact the applicable power utility company?
Are you talking about an EFLI reading on a final circuit or the external EFLI (Ze) ?
It is prohibited to alter or tamper with equipment belonging to the DNO or the electricity supplier.
Thanks Guys. I was talking about the external loop, however I have established that in the UK the DNO is responsible for that cable and I will just alert them. Yes PEN conductor is illegal after the customer point of control. In SA the DNO stops at the meter in the kiosk outside the property. Therefore you have a cable feeding the installation from the meter to the point of control. Sometimes the earth on this cable deteriorates and a earth/neutral bond is then made in order to restore a proper earth.
Even in that scenario it would be unacceptable to make such an earth/neutral link. If the earth conductor has deteriorated then the cable is damaged and must be replaced (or repaired if possible)
Reply to Earth Loop too High in the UK Electrical Forum area at ElectriciansForums.net
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Been asked to do some rewiring, and have said needs upgrade of consumer unit really Main question is regarding earthing - Zs reads at 0.45 ohms...
I have a box powering three 3-phase motors off of one 240V single phase line, NEMA 10-30. In the picture you can see a wiring diagram. The...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
