Wetroom Store - Network Wetroom Suppliers
Advertisement - Content continues below
Discuss Earthing a mouse/keyboard in the Electrical Forum area at ElectriciansForums.net
Hi all,
I am an amateur and have been checking EF measurements around my house. The computer seems quite a large source and I'd like to reduce my exposure.
Can a keyboard/mouse be earthed/grounded with a contact wire on the item running to Earth on socket/radiator?
I thought of using an earthing mat under the keyboard, but running a discreet wire from a contact point to Earth may be a better solution at work!
Many thanks in advance :)
Aico Carbon Monoxide Detectors
B
Bobster
There is absolutly nothing to worry about by the "EF" given off by your computer.
It would be far more productive and critical to life in remembering to look before you cross the road.
Do you use WiFi for your internet on your PC? That's probably the source of your high EMF readings.
There is no proof that the regular EMF levels you are subjected to on a day to day basis from WiFi, Mobile phones, microwaves etc are harmful.
If you are having migraines or any of the other symptoms that people often attribute to EMF exposure I would go and see you doctor, the problem lies elsewhere.
Silly Sausage
I feel much healthier these days since I started Earthing my tin foil cap. I find it also gives a greater connection with Mother Earth.
DPG
Advent Win
The electrical fields given off by things around you will be far higher than anything emitted by a keyboard. Things like mains wiring, pylons, underground cables, but especially mobile phones, cell towers and WiFi routers.
There's no avoiding things like this these days unless you make your house out of lead, which I believe the fourth little piggy is doing in the forthcoming follow up story.
telectrix
Mentor
had same problem. after a few hours and copious amounts of Jack Daniels, I came up with the solution. here's me in my lab.
and i get brilliant 4g reception on my mobile.
Gavin John Hyde
Just remember if you have PME and you cover the outside of your house or windows in tin foil you must install an earth rod as you can not export the PME outside without a suitable sized earth.
Strima
I tried to earth my mouse once but the cable kept on getting wrapped up in his wheel...
snowhead
Mentor
I've been working with electricity and electrical appliances for over 50 years and ʇᴉ ɯoɹɟ sʇɔǝɟɟǝ llᴉ ou ʎlǝʇnlosqɐ pǝɹǝɟɟns
Reply to Earthing a mouse/keyboard in the Electrical Forum area at ElectriciansForums.net
Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Top Bottom
